She's dead
Old May 19, 2004 | 09:05 PM
MnTom's Avatar
Check the codes here: https://www.dieseltruckresource.com/...n&onlynewfaq=1
But read this one first: https://www.dieseltruckresource.com/...threadid=43476
Tom
Old May 19, 2004 | 09:11 PM
DF5152's Avatar
check my page for the codes
Dan
Old May 19, 2004 | 09:13 PM
phox_mulder's Avatar
P0500 No Vehicle Speed Sensor Signal
P1765 Trans 12 Volt Supply Relay Control Circuit
P1693 DTC Detected In ECM Or PCM
None are VP44 related.
Are you sure you're fuel sender is on the up and up.
Perhaps you just ran out of fuel, very out of fuel, and the 1.5 gallons wasn't enough.
Or, you have an air sucking hole above the level of the fuel?
Did you try cracking the injector lines and checking for fuel there?
phox
Old May 19, 2004 | 09:53 PM
csutton7's Avatar
pop some injector nuts and crank her over until you get fuel out of them--then close em up and she should start shortly--chris
bluebull's Avatar
I would check what phox suggested, just crack a couple of injector lines to get the air out from between the injector pump and injectors, loosen at least one turn on two to three injectors, wrap a shop rag around the fitting to absorb the diesel when it starts shooting out, it will run rough but will start, you can tighten fitting while truck is running.
Old May 19, 2004 | 09:58 PM
gcookieman's Avatar
When what fuel I have in my tank is cooling my vp i dont think iam going to let it even get to 1/4 of a tank. Just my opinion.
Cookieman
Old May 19, 2004 | 10:09 PM
Haulin_in_Dixie's Avatar
Joe a couple of months ago, I was stopping for fuel, stopped at the light at the exit. Had just under 1/8 tank. When I started from the light it lost prime. I walked to the station, filled a can, walked back and put in three gallons. It took forever to get a prime up and involved cracking lines etc. Finally it caught and fired up. Lost about three hours in the middle of the night fooling with it. All that had happened was that I picked up a slug of air with the engine wound up.
I would try cracking three of the lines and see if you get fuel. If you do it should start.
Old May 20, 2004 | 01:47 AM
BigBlue's Avatar
I'd try what the others suggested. If it is your VP, I'm still impressed that you got that kind of mileage out of it regardless. And all of that mileage being bombed.
Old May 20, 2004 | 06:03 PM
Originally posted by BigBlackDodge
had mechanic check Lp and cracked some lines - no go.
Installed a rebuilt VP$$ and she runs like a top. No more hesiitaion at low rpm's in 3rd or 4th gear anymore. She's runing like a top.
Glad you are going again Joe, hope your work load is better than mine right now...
Old May 20, 2004 | 07:47 PM
J BODY's Avatar
Also be aware of the infamous 1/4 tank syndrome. Over the years I've had many tow ins due to the fact that the tank had simply run dry, but the gauge showed 1/8 to 1/4. My latest one I drove to a good customers home and got his truck started by rolling it out of the drive way and loosening the injector lines. We drove it a few blocks to the station and it took 33.7 gallons. As dodge owners we all know that there isn't a truck out there that will take that much fuel if the gauge is showing an 1/8th or more. Most of the time when the low fuel light comes on the tanks will only take 26-28 gallons, if everything is working to par. food for thought..........
Old May 21, 2004 | 08:52 AM
Copenhagenjunkie's Avatar
BBD,
Ya came right thru RockSprings and you didn't even stop! Well if your ever up this way again give me a shout. I-80 exit 103 then 1 mile south to the college.
Glad to hear your up and running again.
Copenhagenjunkie.
