Setting Timing on CTD??
Old Aug 23, 2007 | 10:03 PM
SilverRam3500's Avatar
Can this be done? Setting or adjusting timing or checking timing at least?
Can I do this myself or need a computer?
I want to know if my timing is set right. I have a truck that has a reman VP and I got it like that and but I'm not sure the timing is 100%.
Can someone explain or let me know how or what to do?
I tried looking up info on this but no luck!
Thks T
Old Aug 23, 2007 | 10:28 PM
displacedtexan's Avatar
You have computer controlled timing on your truck.
Old Aug 23, 2007 | 11:28 PM
OK computer controlled but can it be adjusted or checked?
When the VP was installed was timing supposed to be set? How can I verify the VP was set up right or is there only one wAy? THks!
Old Aug 24, 2007 | 12:59 AM
Dinner's Avatar
I don't think you can set up the VP wrong(timing wise) The VP slides into the timing gear, and lines up using a key-way. This key-way makes sure that the VP is in timing with the engine...so there is no way of messing that up.
And for adjusting the timing through the computer, I'm thinking the only way is to buy a programmer that adjusts it its self. I don't think you can flash the ECM and adjust your timing. BUT I COULD BE WRONG
Old Aug 24, 2007 | 09:24 PM
J BODY's Avatar
timing is set on the test bench. There is a number on your key on the pump shaft that should match the number stamped on the pump info pad.
oldblues
Apr 20, 2007 09:45 PM
BigBully
20
Feb 22, 2007 09:37 PM
Dave88LX
Dec 4, 2006 08:25 AM
West Coast
Oct 11, 2006 10:33 AM
Ram of Steel
Aug 14, 2006 02:20 AM
