It Runs!!!!!
Old Sep 11, 2005 | 10:40 PM
CTD99's Avatar
Smile It Runs!!!!!
Well, during all the cranking I thought I was either going to burn up the starter or drain my batteries... but, it finally started. It didn't take long to figure out I had forgotten to hook up the oil supply line for the power steering pump... nearly 2 gallons of oil on the driveway is hard to miss! So, after that was resolved I fired 'er up again and all seems good.
When I get home from work tomorrow I'm going to do the 20 minutes @ 2000rpm for the cam break-in and then I'll go for a road test. Stay tuned...
Old Sep 11, 2005 | 10:43 PM
Marine's Avatar
Veteran: Marine Corp
That's one way to flush the PS system...
Mike
Old Sep 13, 2005 | 08:29 AM
CTD99's Avatar
I put about 20 miles on the truck last night... drove it to work this morning also. Runnin' good except that I have a MIL (0113) for the IAT that I can't get rid of. When I erase it, it pops right back up. Also, it is running really cold... around 160-165. Guess I'll have to double check the t-stat but I'm 99% confident that it said 180 on it, not 160.
Old Sep 13, 2005 | 03:58 PM
thumper 549's Avatar
congrats!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 14, 2005 | 10:23 AM
storx's Avatar
haha i made the same mistake once.......installed a 160 tstat
Old Sep 14, 2005 | 05:36 PM
CTD99's Avatar
Mil 0113
Anybody know how I can get rid of this MIL for the "IAT sensor voltage too high"?... I have a scanner but when I erase the code it comes back immediately. I am running with the Edge turned off but I still need it hooked up for the boost fooler.
Thanks
~ Russ
Old Sep 14, 2005 | 11:55 PM
CTD99's Avatar
I pulled the t-stat tonight just to verify that it is the correct part... it is a 180 degree t-stat. I also boiled some water to test it and it works exactly as it should. But, I still have not seen temps in the truck over 170 (at most) and most of the time it's right at 165. Should I be worried? Or is it just a combination of fresh coolant and the cooler weather (high of 70) we've been having lately? My truck had always run pretty cool, but not this cool.
~ Russ
RLS
Nov 7, 2007 05:03 PM
wilderness
Sep 17, 2006 08:23 PM
wannadiesel
Jan 16, 2004 03:20 PM
dodgeman01
Aug 5, 2003 01:29 PM
Joe V
Apr 21, 2003 04:26 PM
