running tough
Old Jan 12, 2011 | 01:52 PM
shadow rider's Avatar
running tough
started running extremely rough while going down the road. acts like it not getting enough fuel. has a lot a of dark smoke coming out the exhaust. Its done it before but only last a short time and runs fine for a few weeks. this time it continues to run rough. checked for codes and it showed P0216. It is a 2001, 2500.
Old Jan 12, 2011 | 02:09 PM
rebal's Avatar
check your fuel pressure if your lift pump is out it can give the p0216 code also if you have good psi your injecter pump is probably going out. p0216 is a timing problem in the pump .I have seen them run as long as 40k miles with that code, but if it wont go away your looking at $1000-1500 to fix it
Hoss
Feb 6, 2013 12:42 PM
Cummins Freak
Jan 17, 2007 11:29 AM
Dodgezilla
Mar 19, 2005 05:45 PM
Commatoze
Apr 7, 2004 05:11 PM
