Run engine with no trans?
Old Apr 13, 2007 | 12:32 PM
mvanhelden's Avatar
I'm putting a south bend clutch in, while i was at it i installed a new crank seal, would it be ok to run the engine witht just the flywheel and no clutch/trans? i want to set the high idle for a while to see if the seal leaks before i assemble everything just to be safe. would it throw the engine off balance or anything? should i support the back of the motor?
Old Apr 13, 2007 | 12:46 PM
dodgezilla04's Avatar
without very securely attaching that 930 or so # motor to the frame, I wouldnt do it. when she fires off, she'll torque over and when shutting down. i dont recommend it.
it will not affect balance of the motor, you just dont have 33% of the engine support in the truck.
Old Apr 14, 2007 | 02:24 PM
mvanhelden's Avatar
would there be anything that would get streached too tight or anything becuase of the engine moving around? Just hate to ruin a 900 dollar clutch in a hundred miles because of a defective seal.
Old Apr 14, 2007 | 08:13 PM
OutlawR6's Avatar
Do not start your engine without the trans and all supports to hold it in place. These things rock around pretty good when shut down. I would be worried about the engine beating aginst one of the fenders or other parts in the engine bay.
Old Apr 14, 2007 | 08:42 PM
Rsquared28's Avatar
The engine is not going to beat around the fenders.
It may rock back and forth because of the mid-engine mounted engine mounts. I would set up jack stands at the front and rear of the engine and let it rip. As for clearences, the fan and shroud would be my biggest concern.
Anytime I replace a rear crank seal, I always run the engine and drop the flywheel back down to check the deal.
Old Apr 14, 2007 | 08:56 PM
johnh's Avatar
i have never heard of running an engine to check a new rear seal...i have re built hunderds of engines ,never had one leak while under warranty
Old Apr 14, 2007 | 09:41 PM
Rsquared28's Avatar
While good technicians rarely screw up crank seals, I have had to replace seals for a lot of young inexperienced techs. It has been standard operating procedure to run engines with no tranny in several shop I have worked at. Let the engine run for 15 - 20 minutes, grab a cup of coffee, whatever.
This is a lot easier than having to deal with an angry customer, or pulling the transmission back out later on.
Old Apr 14, 2007 | 10:11 PM
TheBigNasty's Avatar
I have bought brand new bad parts. Just because it is new doesn't gurantee it is not defective.
Old Apr 14, 2007 | 11:56 PM
johnh's Avatar
of course i realize things can change with time, i retired from automotive repair in 1986 but like i said, i never heard of it
Old Apr 15, 2007 | 01:56 AM
mvanhelden's Avatar
It's not if i installed it right but being i purchased the seal at kragen makes me worry, it's a felpro seal, are those good seals? But if by some chance it's defective, then goes a weekend on pulling the tranny out, and 900 bucks because of an oil contaminated clutch disk. So nobody's ran there dodge with no trans?
90 power ram
Oct 6, 2011 08:04 PM
Totallyrad
Sep 25, 2010 11:15 PM
ppsi
13
Apr 13, 2004 03:49 PM
