Rough Idle ...something to worry about?
Old Aug 9, 2007 | 06:00 PM
Pinkston's Avatar
This is a question about the truck in my signature. While sitting still idling I have noticed my truck has a somewhat odd idle. It generally idles around 750 rpms and the needle flutters a little bit. While idling I feel/see a drop in rpms every 10 - 15 seconds. It seems like it drops about 50 rpms and then jumps back real quick. If you blink you would miss it. There arent any codes, FP stays between 12-15 psi all the time. Is this anything to worry about?
Old Aug 9, 2007 | 09:00 PM
JSPulliam21's Avatar
The way I understand the tach operation is: The computer samples engine rpm at certain intervals and "updates" the tach readout. The fluctuation you see is the needle reflecting the updated engine speed.
Old Aug 10, 2007 | 12:44 AM
nickg's Avatar
if its cycling every 8-10seconds it sounds like the AC is cycling, rotate the heat control to OFF as the ac will cycle in the other posns as well. its normal to see a rpm drop when the AC cycles
Old Aug 10, 2007 | 05:10 PM
Pinkston's Avatar
My AC was low on freon. I fixed that problem last night right before I made this post. That was the problem. The AC compressor was cycling on and off making the RPMs flutter.
banks twinram
May 18, 2010 08:10 PM
ramdez
Dec 28, 2009 03:55 PM
nfsommer
Nov 21, 2006 08:22 AM
Dodgezilla
Oct 25, 2004 11:28 PM
Rolngthun
Oct 13, 2003 03:13 PM
