Reset APPS...fuel mileage is back!
Old Aug 15, 2009 | 04:27 PM
  #31
uber racing's Avatar
Originally Posted by tool
Well to test your theory I did the voltage adjustment procedure This weekend on my '99 MANUAL truck. It has had severe dead pedal problems especially just off idle (like going through a school zone and applying very light throttle) it woul cut to idle, trigger the CEL light and not respond to foot feed input until you press the pedal 3X.
The tag on the back of my APPs read .535 Volts, I found by probing Pin 23 on PCM that it was registering .290 I adjusted according and got dang close to .535 put everything back together. Started it up and it immdeiately began to "idle" at 1400 RPM !
Wondering what the heck I might have done I decided to drive it a little and see what it would do, ran fine just idled high. So........ I turn around to go back home and truck tripped the CEL light and cut to idle, no amount of fiddling with pedal would make it run normally. SO I idled the 3 miles back home in 3rd. SHut truck off, pulled codes with my scanner and got a whack of APPS related codes and "input voltage out of range" etc. cleared the codes started 'er back up and now it seems to be working perfectly!! No more dead pedal, no more APPS codes. I have put about 500 miles on it so far.
Seems as though this procedure was VERY worthwhile on my MANUAL tranny truck.
I just finished setting up my APPS and doing the ATS transmission wiring fix for eliminating the 4th gear hunt. I have the same scenario as above. 1400 RPM idle speed. My Initial APPS voltage was .446vdc. the tag on the sensor was .591vdc. I was attempting to get 1.2 - 1.5 vdc as suggested in a set up article on Geno's Garage. I followed the correct reset procedure for the APPS. I've driven the truck around a bit but it hasn't thrown any codes and hasn't adjusted the idle down on its own as yet.
Will this idle correct it self from a learning cycle? Or should I readjust the APPS voltage down?
Tacomaman87
Jun 18, 2010 06:13 PM
supr
18
May 21, 2007 09:29 AM
Luckycharm1
Sep 4, 2005 04:57 PM
PDXDodge
Jun 2, 2005 02:58 PM
MoreSmoke
Feb 14, 2004 08:51 PM
