Required Pressure for Engine
What IS the required fuel pressure for the 5.9 24V? Almost every lift pump that I look at has a 2-6 or 3-8 PSI rating. From what I read the Cummins is 12-15 @ idle PSI so why is that so high? I think the huge semi engins are still low pressure pumps and marine engines all have the low pressure pumps so what gives?
Very long debates have been had about this topic. I think the results bear this out: Anything over 1psi to the VP is still positive pressure at the IP inlet, but more is better. The VP bypass opens up at 14psi so, by deductive reasoning, 15psi at all times would be awesome since you have the most fuel pressure that the IP wants. I personally have my LP bypass set at 24psi before the fuel filter and see 22psi at the IP. I also don't want to see the psi drop to nothing at WOT. Confused yet?...
Big Rig
19
Oct 21, 2004 09:24 PM
Mcmopar
Mar 8, 2004 09:08 PM
69D100
Feb 25, 2004 04:11 PM
phox_mulder
Feb 28, 2003 10:32 PM
