Replacing VP44 today,, some questions
Old Nov 29, 2008 | 11:02 AM
robert78.5's Avatar
Well I started at 9.00 am and it is now 11.00 and i have the old one out.
My replacement has the words "remanufactured in USA" stamped on number plate. My old one does not. I am just curiuos as how can I tell if my old one is the original.
Old Nov 29, 2008 | 11:47 AM
BigIron70's Avatar
Cummins Guru
If it is not painted it is most likely original. Replacements are always painted black. Just be careful you don't get any paint chips in fuel lines when installing also be glad that remanufactured in Mexico isn't on label
Old Nov 29, 2008 | 12:17 PM
J Lent's Avatar
All the reman. I've seen are usually stamped. On the top cover, are there any numbers?
Old Nov 29, 2008 | 05:06 PM
robert78.5's Avatar
Numbers look like factory numbers. I have it installed. Not to bad of a job. Started pretty easy.Now for the highway test.
Old Nov 29, 2008 | 07:24 PM
robert78.5's Avatar
Well i did one warm start and so far so good. I did notice one thing. On my old pump i could spin the taperd shaft very easy almost as if there was no friction inside. The new pump had some resitance when i spun shaft. Maybe my head was wore out. I am going to take old one apart on Monday just to satisfy my curiuosity.
Old Nov 30, 2008 | 08:31 PM
robert78.5's Avatar
Well i made 330 kms trip today and the truck worked excellent. It started every time I wanted it to. Overhead was marking 21-23 mpg all day on the highway. I will do an actual check on paper when i fill again.
Old Nov 30, 2008 | 08:34 PM
scottsjeeprolet's Avatar
I wouldn't take the old one apart if you need to send it in as a core.
Old Dec 1, 2008 | 09:13 AM
robert78.5's Avatar
Yes your probably right., Will i have to get high idle reinsatalled or is it stored in the ECM?
Old Dec 1, 2008 | 10:25 AM
johnh's Avatar
you won't have to do anything, the high idle will still work
chiefallred
Jan 24, 2007 07:11 PM
Flatty
Nov 21, 2005 10:38 PM
rigby38
Sep 12, 2005 07:57 AM
Zeddy
Sep 4, 2004 10:04 AM
Yukon Dodge
Jun 22, 2004 06:32 PM
