replacing ball joints
Old Jul 18, 2010 | 11:43 PM
Silver R/T's Avatar
How hard is it to replace ball joints on 01 2500?
Old Jul 18, 2010 | 11:47 PM
R.T.D.H.S.P.'s Avatar
2wd or 4wd?
Old Jul 18, 2010 | 11:51 PM
Not very hard if you are well prepared. The factory ball joints are held to the control arms with rivets which are impossible to get out without the use of a grinder, air chisel, a big hammer, center punch, and some cold beverages. The new ones go in fairly easy being that bolts are used as replacement for the rivets. Took me about 5 hours with the tools described.
Old Jul 19, 2010 | 12:14 AM
Silver R/T's Avatar
what size ball joint separator do I need?
Old Jul 19, 2010 | 12:31 AM
Nothing too big of one... A good trick is to loosen the ball joint nut until it is just flush with the end of the threaded stud and give it a few good whacks with a hammer. Most times after a few whacks, it will let go...what model is it? Is it 2wd or 4wd?
Old Jul 19, 2010 | 11:43 AM
DieselNomad's Avatar
Do a search on here,there is lots of helpfull info in about a thousand post of this very nature.you should be able to find what you need with a search.
firebill1720
20
Mar 5, 2010 09:23 AM
C/PRD/
Feb 23, 2008 06:22 PM
nfsommer
Mar 30, 2007 05:17 PM
MR. GADGET
Sep 8, 2006 10:29 PM
HydraulicGuy
Nov 17, 2004 05:30 PM
