03 Replacing Ball and Axle joints!
Old Feb 23, 2008 | 04:40 PM
C/PRD/'s Avatar
I have my passenger side tore apart on my 03 and I cannot remove the hub assembly. Does the entire axle shaft have to come out on these AAM's or what. I have every bolt out of this thing and it just wont budge. Do I need to pull the diff cover and remove some sort of retainer or what? Thanks
Old Feb 23, 2008 | 04:50 PM
booman70's Avatar
You need to push it out form the backside. Put the four bolys back in almost all the way then using a extension between boly abd axle housing use power steering to press bolts pushing bearing assemnly out do one bolt at a time rotating around and backing the bolts out a little more and doing it again till you can remove
Old Feb 23, 2008 | 04:54 PM
C/PRD/'s Avatar
Thanks Booman.
Old Feb 23, 2008 | 04:57 PM
booman70's Avatar
Take a look at this thread helped me get mine apart to do axle ujoints scroll down to papaduck writeup
https://www.dieseltruckresource.com/...ve+hub+bearing
Old Feb 23, 2008 | 05:56 PM
C/PRD/'s Avatar
Thanks for the input but my power steering said NO! I will not push that hard!LOL so I think the BFH is gonna be in order.
Old Feb 23, 2008 | 06:05 PM
C/PRD/'s Avatar
What options do I have for manual locking hubs to put in this big piece of $h!t. I am begining to hate this truck! Is there a servicable bearing for these things that doesn't rust solid like these?
Old Feb 23, 2008 | 06:22 PM
booman70's Avatar
I used alot of pb blaster and had to really crank on it. As far as free spin hubs there is dynatrac ems and a third one I saw the other day cant remember the name maybe someone else will chime in. i would go for one with the studs already pressed into the hubs.
firebill1720
20
Mar 5, 2010 09:23 AM
Wulzcat
Dec 19, 2009 05:15 PM
MR. GADGET
Sep 8, 2006 10:29 PM
getblown5.9
May 2, 2006 10:01 PM
