Removing MAP and IAT
Old Jun 11, 2008 | 05:27 PM
Scarlet HO's Avatar
What size socket is used to remove these?? Seems I remember reading here 22mm. Are both sensors the same size?? Reason I ask is I have to go buy a socket and I need to get these things off tonight so I can take them down to the Cummins dealer tomorrow.
Thanks for the help!
Old Jun 11, 2008 | 05:38 PM
AggieJustin's Avatar
1-1/4" needed to pull the MAP.
13/16" for the IAT.
Part numbers for the IAT:
Cummins PN 3408345
Dodge PN 05014197AA
MAP sensor will vary depending on year. You can also give the Cummins dealer your engine serial number and they can look the number up for you.
Old Jun 12, 2008 | 11:39 AM
CORed's Avatar
Out of curiosity, how often do you replace the MAP sensor or can it just be cleaned too?
Old Jun 12, 2008 | 03:19 PM
You should just be able to clean it up. Only needs to be replaced if you're having sensor issues.
Old Jun 13, 2008 | 06:10 AM
lloydster's Avatar
why are you changing them? are you having issues or just preventative? what does each do? my 98 has low pulling power. have a crack in my exhaust mani to fix. would doing these sensors help?
Old Jun 13, 2008 | 08:30 AM
xtoyz17's Avatar
It's probably the crack. Losing exhaust before turbo = low boost.
Old Jun 13, 2008 | 08:19 PM
Scarlet HO's Avatar
I cleaned the MAP and put it back in but it still threw the P0237 code. So, I ordered a new MAP and since I had read a few posts on here about the IAT causing problems, I figured what the hey, I just got the truck last Saturday so I figured I would start replacing things that gave me issues. Thanks for the tip on the sizes, the MAP sensor actually wound up being 1 1/16. I did have to get the pig tail for the new sensor though. It is amazing how much the *********** marks parts up! I found the local Cummins dealership where I live and got my parts for the same price as on the net, plus I got to get some scopp from their service guys while I was at it!!
Old Jun 15, 2008 | 09:32 AM
lloydster's Avatar
what were the symtoms b4 map & iat replacements &the result after? which sensor required the pigtail& what the parts run you @ cummins?
Old Jun 15, 2008 | 12:48 PM
Scarlet HO's Avatar
My truck was showing the error code P0237 which says low voltage for the MAP sensor. I tried cleaning it but it continued to throw the code. The new version of the MAP sensor has a different end on it thus requiring the pigtail. The Cummins part number is 3104228 and costs around 11 bucks. You can get it here http://www.hoeslidiesel.com or at a Cummins dealership. Don't go to the *********** as they get almost 50 bucks for the pigtail alone.
Old Jun 15, 2008 | 08:58 PM
Random Acts's Avatar
Went looking for an inch and a quarter
13/16" for the IAT.
Cummins PN 3408345
Dodge PN 05014197AA
I went looking for a 1 1/4" deep socket. Started at OSH then Lowes, Sears, Home Depot, Auto Zone. Everyone went up to 1 1/8" and could get the 1 1/4" in a few days. Some had the 1 1/14" in regular socket. While I was at Sears I picked up a Gator (Socket with sping loaded rods that fit everything) that went up to 1 1/4" but I was not sure it was deep enough. I took the gator home and it was not deep enough. So I took a rod and pounded out the rods from the inside out. Always wondered how those things worked anyway. Rods came out easy and the socket left over was a perfect fit for my map sensor.
Old Jun 16, 2008 | 11:28 AM
91rangerturbo's Avatar
You gotta do what you gotta do.. haha
Old Nov 10, 2008 | 06:41 PM
imbodie's Avatar
Talking IAT replacement.
Boy... learned my lesson tonight. Thought I was just going to take it off and clean it, ended up breaking the plug housing on the sensor....
Heads UP, if your going to try this for the first time, just replace the sensor. Have one IN HAND before you start.
I'll post back after I've driven the truck a few days to see how a new one worked out. However, the only place I could find one was my sorta local dealer, and it cost $35. Everyone else would have to order it and upwards of two weeks to deliver.
-Tim
afoulk
17
Apr 14, 2009 01:32 PM
Valv
Feb 20, 2008 08:07 AM
SuperDave4x4
Sep 5, 2006 02:35 PM
BigBlue
15
Mar 28, 2005 01:20 AM
