Removing the ABS system
Disconnecting the ABS system
Is it possible to disconnect the ABS system, and just have the brakes lock up when you really stomp em? I've had more tight squeezes because of the daggone ABS than if she'd just locked the brakes up. At least then you're stopping, not buzzing and continuing your journey through the intersection with the opposing tractor trailer. I'd rather they just function like regular truck brakes.
Hate to say this....but you stop WAY better with the tire rolling than locked up. You have better control. (Just like you dont want tire spin when drag racing) Hence the ABS. You just have to use them correctly for them to work right. Stomp em to the floor and hold them and steer......OR drive slower and look ahead more!! hahaha.......
You can yank the fuse...but chances are that you will loose something else in the process. Not to mention that peskey ABS and Brake light always being on!!!!! OR disconnect the pump....but same results will happen...
All in all...i wouldnt mess with it.......
ABS doesn't allow you to stop quicker or shorter distance, it allows you to control the vehicle, steer around whatever you were panick stopping to avoid,
except in icy conditions, then it might actually allow you to stop in less distance.
To answer your question, pulling the ABS fuse will disable it, but you'll have the ABS warning light shining in your face all the time.
phox
phox
I have to respectfully disagree. Any Race school will teach you to hit the brakes with out locking the tires up will stop you faster. Why do you think that the Older Dodge Vipers (without ABS) cant stop as well as the 'Vette?(with ABS). The ABS is just the electronic way of regulating this. It keeps the tire from locking up thus increasing traction when tryng to brake. Most people dont know how to properly operate the ABS system, rendering less effective.
phox
phox
Yeah, about like Torquefan is saying. Daggone thing won't stop. When I want the truck to stop RIGHT NOW it's like it trys to fight back and keep rolling. I wish I could change that, it sucks.
Right...i can see your point...but for the people out there that mash the pedel and LOCK up all 4, ABS will Stop fast in that situation! I would guess that 80-90% of people out there dont have an idea about threshold braking. ABS is a crude version that helps thoes people from locking up the brakes. I didnt say it was perfect! haha.....i can agree to that!
Ive been in the mud when the thing kicked on.........
If you crunch the rear of someone's car and their attorney discovers the ABS had been disconnected, it won't matter if you would have traveled farther with it hooked up.
He'll convince a jury it would have stopped 20 feet shorter with it active.
True. I'm a commercial vehicle too, DOT would taser me repeatedly if they found I'd unhooked it. Crap. Well, going to nappy then and getting the GM brake cylinders. Hope the 07's have better brakes, I'm hoping to be pulling with the baddest 3500 flatbed you can buy next year. Then the 2500 gets some fun upgrades for mud, running over deer at full speed, and outrunning fords.
fitzydog
21
Oct 11, 2017 12:09 PM
3J1&3J2Bill
Jan 28, 2011 11:03 AM
duallydave
May 30, 2007 12:23 PM
mr T
Feb 24, 2007 06:42 AM
