Removing ABS
Old Sep 10, 2009 | 07:03 AM
Jr B's Avatar
Removing ABS
I have a 97 12v and i was thinking about removing all the abs stuff. the rear brakes lock up on ocassion so its not like it works the best to begin with. i realize the light would come on but would it affect anything else?
thanks
Jr
Old Sep 10, 2009 | 08:02 AM
kawi600's Avatar
If you have RWAL brakes versus a full ABS system, maybe your pickup sender on the rear diff is bad?
Ive often wished I had ABS since the frotn brakes on mine lock up so easy in a panic stop. Its hard to manually modulate the pedal in such a short amount of time
Old Sep 10, 2009 | 08:35 AM
Jr B's Avatar
yeah i hear ya, mine is 4wheel abs. but all the brake lines and proportion valves make it a pain in the *** to work on. i feel if i removed it, it would make my life easier.
Old Sep 10, 2009 | 12:29 PM
GAmes's Avatar
To turn the light off all you have to do is unplug the abs controller under the dash.
Old Sep 10, 2009 | 01:17 PM
Jr B's Avatar
But other than the light coming on, it wont affect anything else, correct?
Old Sep 10, 2009 | 06:08 PM
GAmes's Avatar
It will totally disable the ABS. Other than that, nothing else is affected. Mine has been unplugged for years. It HAD rear wheel only though.
Old Sep 11, 2009 | 11:00 AM
Jr B's Avatar
Cool, thank you.
Old Sep 14, 2009 | 12:17 PM
Rattlerattle's Avatar
Mine had 4w abs, pulled the fuse and the abs light came on. Took out the light. It was down right scarey in deep snow, brake pedal would go to the floor as the abs kicked in and the truck would keep rolling. I would much rather have the tires lock up and skid that not stop.
Old Sep 14, 2009 | 02:06 PM
Jr B's Avatar
Sweet man, looks like that craps coming out soon
Old Sep 14, 2009 | 05:17 PM
I took the sensors out of the front the next time I was doing front end work but would advise to leave the back one in so you don't get dirt etc in the rear diff. You should be fine leaving the sensors on the front but they had to be disconnected when I was doing my front u-joints.
Old Sep 15, 2009 | 07:15 AM
Jr B's Avatar
cool, thank you sir.
Old Sep 15, 2009 | 05:03 PM
Fueling around's Avatar
Can a person disable RWAL by grounding out the 4WD sense on the controller?
fitzydog
21
Oct 11, 2017 12:09 PM
3J1&3J2Bill
Jan 28, 2011 11:03 AM
duallydave
May 30, 2007 12:23 PM
mr T
Feb 24, 2007 06:42 AM
Timberman
13
Mar 29, 2006 12:05 PM
