Remote mount fuel strainer?
The little in-line strainer that came with my FASS HPFP is a PITA to change and due to it's small size, needs changing regularly. I'm thinking a spin-on filter with the same micron size (24) would be just the ticket. The search I did came up mostly with stuff for big line apps.
Has anyone tried this with a relatively stock fuel flow and if so can you share your results and hopefully some part #s? I'm picturing a small spin-on filter on a remote mount between the tank and the FASS pump.
Thanks! Randy.
Thanks! Randy.
