Redline on the 24V Motor
Old May 27, 2011 | 11:34 AM
tanderson2002us's Avatar
From: Newman Lake, WA (But my home is deep in the heart of Texas!)
Since I added the Smarty, Edge and straight piped the 4" exhaust I love to rev. the motor at home, smoke a bit and have some fun. I was wondering if the 24V motor will automatically de-fuel before exceeding the redline on RPMs? Or when we do the "snap test" for emmisions we are supposed to give it full throttle a few times. Can we hurt anything if we rev. the motor too high (in N of course)? Or does the rev. limiter prevent over reving the motor?
Just curious.
Thanks !
Tom
Old May 27, 2011 | 01:14 PM
KATOOM's Avatar
I understand the rev limiter will stop the RPM's but a stock 24v shouldn't rev any farther than 4000 RPM anyways. The only time you can override the rev limiter is coming down a hill with and allowing the RPM's to exceed the red line.
Old May 27, 2011 | 01:56 PM
Thanks!!!
With that being said I need to get the valves done...I am at 122k now with no valve adjustment yet.
So I guess it's o.k. to rev. up to the redline sometime I guess?
Tom
Old May 27, 2011 | 04:50 PM
dssimecek's Avatar
Does WA State do emissions on diesels? TX and AZ don't.
Old May 28, 2011 | 06:21 AM
swordfish's Avatar
Correct me if I am wrong, but won't a stock truck de-fuel and/or cut off when you hit 3200 rpm? I just had an experience last week where I got to about 3200 while in second gear and when I went to shift to 3rd and push the go pedal nothing happened. The truck had died. I pulled over, looked everything over, switched the fuel relay in the fuse block and turn the key back on and fired up. Hasn't missed a beat since. I have since switched the relays back to original position and still running fine. Do I have something else going on here? If so, I will start another post, but that is my experience.
swordfish
Old May 28, 2011 | 11:12 AM
KATOOM's Avatar
swordfish
It sounds like your experiencing what I've hear about, where the VP literally runs out of fuel because of your aggressive fuel box. At least that why guys think its happening since there's nothing else to point to, and it only happens to guys with those boxes. I've read some threads regarding but maybe you'll want see what you can find out.
Old May 28, 2011 | 11:37 AM
Silver R/T's Avatar
Yes WA does emissions on diesels. I had to do it last year on my truck.
Old May 28, 2011 | 01:04 PM
SIXSLUG's Avatar
I've never smogged mine in WA
CumminsRedneck
Oct 13, 2014 04:49 AM
king5335
26
Jan 17, 2010 07:57 PM
buddy26
16
Jan 14, 2009 07:29 PM
adidasman23
Nov 1, 2006 03:29 PM
Diesel-Dan
66
Sep 17, 2004 08:01 PM
