Recent fuel mileage drop
Old Aug 1, 2013 | 06:35 AM
Lurch519's Avatar
I have noticed a fuel mileage drop of about 3mpg as of late and was wondering if there is any wierdness going on with the fuel lately. I do not show any trouble codes, tire pressure is right where it has been for the last few years and the only real changes I have made to my truck have been the addition of new front springs and rearching of the rear springs that result in about a 1 to 1 1/2 inch lift and the new tires listed in my sig. My girlfriends Jeep CRD also has had a significant mileage drop. We use the Howes "meaner cleaner" as the fuel additive, any words of wisedom anyone might have as to a possible cause ?
Old Aug 1, 2013 | 06:41 AM
high bid's Avatar
You installed new wheels and tires....this could be your issue.
Old Aug 1, 2013 | 07:36 AM
patdaly's Avatar
Just pushing 1 to 1-1/2" more air due to the lift is going to kill some mileage.
Also, you are correcting for the additional mileage traveled without you Odo showing it? For instance, my 97 runs 235-85-16's, which requires a 1.046 correction factor for miles traveled.
Old Aug 2, 2013 | 01:01 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
I lost about the same when I changed from old hard worn tires to fresh new soft tires. More rolling resistance... seems like it wouldn't matter but I lost 3 mpg.
Old Aug 2, 2013 | 07:51 AM
Ed ke6bnl's Avatar
I lost milage with the same size tires then changed gearing to 4.10:1 that help a little and was what I wanted for towing 5er
Old Aug 6, 2013 | 06:19 AM
Lurch519's Avatar
I talked with the guys at a local Cummins shop and when they heard that I had 247,000 miles on the original injectors, they thought that I might have some erosion going on with the injectors. No appreciable smoke at the tailpipe ( I ran 2% opacity at emissions in march) . The fact that it has been doggone HOT here I have been cranking the A/C and now most people ( that are not mechanics) are saying that must be the cause. Probably a bunch of little things adding up, most likely. Thanks for your opinions !
Old Aug 13, 2013 | 11:07 PM
oldkimmer's Avatar
.................get ur valves adjusted...........kim.......
Old Aug 15, 2013 | 08:31 AM
Lurch519's Avatar
Valves were adjusted last spring. Running the A/C full tilt boogie this summer seems to be the most likely culprit. This is the first summer I've had A/C in about three or four years. Kinda nice !
Old Aug 15, 2013 | 09:18 AM
Ed ke6bnl's Avatar
when you run your heater in the winter the a/c comes on as well
Old Aug 15, 2013 | 10:13 AM
nothingbutdarts's Avatar
Partially correct, the A/C compressor only comes on when you have your heater in the defrost mode.
Old Aug 17, 2013 | 05:07 AM
Lurch519's Avatar
I did not know that
Old Aug 17, 2013 | 11:44 AM
Tallguy67's Avatar
Lurch, the A/C thing when defroster is on is true. I have heard two theories why. I give more credence to the first theory.
1 - the a/c makes the defroster run so that the seals in the a/c system don't dry up over the winter
2 - the a/c dehumidifies the air (which makes sense) so that the defroster doesn't have to work as hard to keep the windows from fogging up / frosting up.
I have never been totally sure why the system is built this way, but it has been like that in any car or truck I have ever had that had a/c.
Old Aug 19, 2013 | 02:37 PM
Ding Ding Ding, we have a winner Johnny!!!!!!!
Old Dec 28, 2018 | 09:03 AM
Troy Zeller's Avatar
99 dodge 2500 5.9. Hard shift into 3rd
While driving if I slowly increase to 45-50 mph when it shifts it tends to roll a ton of smoke if I'm trying to accelerate quickly. Any thoughts?
Ron R
Sep 16, 2008 11:09 AM
Diesel-Dude
Sep 11, 2008 08:42 AM
NJMurvin
Dec 7, 2004 06:15 PM
bsummit
Jul 30, 2003 11:24 AM
ladyram
Mar 22, 2003 12:53 PM
