Rearend assy options?
Old Nov 19, 2010 | 05:17 PM
tumper93's Avatar
Guy ran a red light and nailed me in the RR wheel and killed the rearend. Got body work fixed now it is time for the rearend to be replaced. It currently has a Dana 60 with drum brakes. Should I upgrade to rear disc since I am going to have to get a salvage unit anyways? What is required to upgrade this and what year models fit in place of the 2001 rear. Since it is a 2001 I hope one from a newer 3rd gen will fit so I can get one with the lowest miles. Any suggestions would be appreciated. I have been a tech for 18 years for GM so the technical part is no biggy.
Old Nov 19, 2010 | 05:22 PM
patdaly's Avatar
You have either a Dana 70 if it is an auto or a 80 if it is a stick or a DRW.
Personally, I think the AAM axle from the newer ones are not as strong. I do think they bolt in though.
If it were me, I would put an 80 under it no matter what, rebuild it if necessary.
Old Nov 19, 2010 | 07:23 PM
Tate's Avatar
AAM's also do not have 3.55's as a gear ratio, so if thats what your truck is (if 4wd), then it would be a no go. I would also look for an 80 to swap in.
Old Nov 19, 2010 | 11:27 PM
rebal's Avatar
2001.5 had disks
Old Nov 20, 2010 | 09:12 PM
tumper93's Avatar
So I need to look for an 80 with disc brakes then. Is there anything that you know of that i will have to switch hydraulicly if I switch from drum to disc? I will surely stay away from th newer rears from what you say. The ratio is 4.10 auto by the way
AggiePhil
13
Oct 9, 2019 09:28 AM
McGyver
Sep 8, 2004 11:14 AM
Mark Thomas
Aug 14, 2004 06:27 PM
6cylinders
Jan 9, 2004 08:08 PM
Mr. Jimmy
Aug 25, 2003 05:28 PM
