Really Need Some Help. New Ip Install
if any of you have seen my recent posts, I have been doing somewhat of an overhaul in the last few days.
It started the other day with a dead truck, giving me the deap IP codes.
Right now I have installed the CAI, stage 5 nozzles, and a new IP. When I go to start it, i get the exact same result. No start. Am I missing something?? Anyone have any tips that I may be overlooking?? I can really use the help at the moment... Is it possible at all that the lp is causing this?? I just replaced it 6 months ago... I am going to be installing the FASS kit next weekend. Should I wait and just do that, or buy a LP and try it out? I really would love to hear it run tomorrow. Any ideas would be priceless. thanks
Double check all connections to the VP ( electrical) . Sure the timing is on? I had one I put on ( man I hate to admit it ) that the shaft rotated and the keyway wasn't matched up! What a mess that ended up being. Don't ever lose the key or mash it like I did. There are over 50 different keys! the are all differend offsets. not just everyone keeps them in stock either! Anyhow, those are a couple of things to check.
Keyway is good, that is one thing I watched with a mirror as I tightened...whats wierd is it is acting the same as it did when it died to begin with. Not even attempting to start
got two of each code, p0122, p1689, p1688, p0380
Tried the apps reset. Then cleared out codes. Not starting, but now only getting the 0380 code. SO the others were probably just from when I didnt clear them before
airplaneman, where did you get your new IP from, Im looking to get one myself, and dont know who to trust--BlueChip is expensive but they have some selling points, and others say anyone is fine because they are all going to have the updates. but I want to make sure the one I get next will go a long way.
sqrl$$
May 21, 2011 11:15 AM
LUKE-MM-PULLER
Feb 19, 2008 09:36 PM
