Read codes...
Old Feb 7, 2007 | 10:13 AM
firepiper's Avatar
Read codes...
P1689- no comm between ecm and injector pump
What does this mean?
Old Feb 7, 2007 | 10:49 AM
CTD NUT's Avatar
Unfortunately, the 1689 DTC usually means that the VP44 ECU likely has some type of damage to its PC board causing a degree of lack of continuity in it.....the bottom line in this case is usually that the VP44 will have to be replaced since the piggybacked ECU is not independently serviceable. An inspection of the ECU connectors might yield something but I doubt it - usually the board is punched.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
DieselDaze
Sep 23, 2003 11:22 PM
Rocketman
Feb 10, 2003 09:52 PM
