radiator flush question
Old Jun 9, 2007 | 03:08 PM
ponygallery's Avatar
Flushing and replacing the coolant in my 2001 2500 4x4. When I open the drain **** I only get 1/4 turn and nothing drains. (yes, I've removed the cap.) I'm not sure if it's just clogged from 144.000 miles or if it turns more than 1/4 of a turn. Any info or Ideas?
Thanks in advance
Cowboy
Old Jun 9, 2007 | 03:27 PM
2500Ram's Avatar
I believe you turn it counter clockwise 1/4 and pull back, toward the engine, it will kinda snap open. Going from memory here as I've never done mine. But read it recently.
Good luck.
Old Jun 9, 2007 | 10:35 PM
Thanks for the info. You're right. I syphoned out 5 gallons of coolent and caught the rest in a drip pan when I removed the lower hose. Once it was out I messed with is and it does slide out. I was shocked to see how clogged up the front of the radiator was. I let a good degreaser soak on it for about 20 minutes and then gave it a good spraying with the garden hose. Lots of crap stuck in there.
Thanks for the info,
Cowboy
CACalomino
16
Mar 22, 2010 06:35 PM
Sam Turner2
Nov 18, 2008 10:17 AM
grantx5
Jan 5, 2008 06:56 AM
dieselfan
Nov 10, 2006 08:01 PM
LFD2037
Nov 8, 2006 09:12 PM
