Radiator flush question?
Old Nov 10, 2006 | 07:30 PM
dieselfan's Avatar
can i use tap water for the flushing part of this http://dodgeram.org/tech/dsl/cooling-sys/antifreeze.htm
also should i buy some type of flushing solution like super flush by prestone?
thanks, dieselfan.
Old Nov 10, 2006 | 07:57 PM
Rammandan's Avatar
i don't see why tap water would hurt anything it would be cleaner than anything else so i say go for it. as far as the flush goes i used it, i'm not sure if it did anything but i bought two bottles and did it right so i wouldn't have to do it again. You might want to look into a bottle of water pump lube i use it in my tractors and also put a bottle into my radiator fluid on the truck you can pick it up at most any auto store.
Old Nov 10, 2006 | 08:01 PM
dieselfan's Avatar
thanks, ill look for the water pump lube tommorrow.
how many times did you flush the rad.?
thanks, dieselfan
CACalomino
16
Mar 22, 2010 06:35 PM
Sam Turner2
Nov 18, 2008 10:17 AM
grantx5
Jan 5, 2008 06:56 AM
ponygallery
Jun 9, 2007 10:35 PM
LFD2037
Nov 8, 2006 09:12 PM
