Question about torque & HP
Old Apr 20, 2003 | 08:13 PM
Xplorer's Avatar
I went to a dyno run on Saturday &amp; had a great time...thanks guys. Here's my question, I ran a 185 HP &amp; 315 ft lbs torque at the rear wheels from a stock auto. Is this what I should expect? I thought it would pull in the 220 range &amp; 350 torque. Is this normal or might I have a problem ??? Thanks for you input. <br><br> Jerry
Old Apr 20, 2003 | 08:29 PM
phox_mulder's Avatar
Re:Question about torque & HP
I did my first Dyno run Saturday as well<br><br>2002 4x4 auto transmission with 3.54 rear end.<br><br>I got a 205.6 HP, no torque due to no RPM hookup.<br><br>Totally stock engine and transmission.<br><br>Only changes I have done that would affect readings are my missing muffler (replaced with length of 3inch pipe, kept resonator and rest of stock exhaust) and my 34.75 inch tires.<br><br>Was told that I am doing very well for a stock truck, and that most other stockers have gotten around 170-180 hp.<br><br>I think you're right where you should be, maybe a little better<br><br><br>phox
Old Apr 21, 2003 | 09:22 AM
KatDiesel's Avatar
thats good...........<br><br>your truck is rated at 215hp at the flywheel. I forget the torque.
Old Apr 21, 2003 | 10:36 AM
NAIL BENDER's Avatar
My truck stock last year, did the same #'s as yours did.
Old Apr 28, 2003 | 07:15 AM
Nuttymopar's Avatar
Don't you loose about 20 % of Power &amp; Torque going from the flywheel to the rear end? So those numbers would be good for being stock then.
joem
Jun 25, 2011 10:16 AM
mitm
Aug 16, 2009 09:29 PM
RIDETHEGLIDE
Mar 17, 2009 02:31 PM
Ridiculous
May 17, 2007 07:28 PM
Mark Hodowanec
Feb 26, 2006 08:35 PM
