Tot torque or not to torque, that is the question.
Old Aug 15, 2009 | 04:25 PM
mitm's Avatar
Bought the permatex RTV gasket sealer made for differentials and instructions say to hand tighten till RTV just begins to squeeze out then wait an hour and turn 1/4 to 1/2 a turn to finish. Dodge TSB says to torque to 30 lbs imediately after applying RTV. I went with the instructions on the sealer and have a nice small bead now just about 1/16 all the way around the outer edge of RTV. This was not enough pressure to set off the torque wrench though. So leave it or torque to spec?
Old Aug 15, 2009 | 07:53 PM
dozer12216's Avatar
Torque to spec immediatelly.
Old Aug 15, 2009 | 08:03 PM
nickg's Avatar
same here apply sealer, and torque right away...never had an issue in 20+yrs twisting wrenches, also I've never allowed sealer to "set" prior to tightening parts..
For what its worth the BEST RTV is "the Right Stuff" from permatex or the GM sealant GMS "also known as GM sealant" these two products are expensive compared to plain old RTV but if you dont want leaks this is the stuff to use!
Old Aug 15, 2009 | 08:21 PM
cliff dodge's Avatar
torque it to the spec asap thats how i was tought and i have never had a problem yet with race cars pull trucks or every day drivers..
Old Aug 16, 2009 | 09:29 PM
dieselcamp's Avatar
I would torque to spec
Firstgenfanatic
May 14, 2008 06:17 PM
mainer
Jul 17, 2007 07:13 PM
PapaSmurf
Dec 19, 2003 02:14 PM
Davidp
Feb 1, 2003 05:49 AM
