Question
Old Aug 5, 2012 | 01:48 PM
Truckman's Avatar
Question Question
Hi all,
I now have to under go the 5th gear nut repair again,,Although it has been 5 years since I last repaired with Dodge's split nut fix. I guess it has to be done every 5 years HAHA ,168.000 miles since repair.,,. The dealership i borrowed the special tool WRENCH, 5TH GEAR LOCKNUT from has lost that tool,So I am getting ready to buy one, But was wondering if anyone out there had one they either wanted to sell or lend, I am going to order it Monday if needed,
Miller Special Tool #6743
Thanks All
Truckman
98.5 Ram 2500 just turned 300.000 miles still going strong in 4th,,
Old Aug 5, 2012 | 08:11 PM
whiskers's Avatar
You just need a good Square pin spanner wrench. Should be able to borrow one from Autozone. And a cheater pipe.
Old Aug 6, 2012 | 06:58 AM
Truckman's Avatar
Cool Padded
I will make sure I use a padded cheater pipe so when it slips off trying to get to that 300Ft Lbs it does not hurt to bad when it hits me in the face,,,,, hahahaha
Calling to order the $67.00 wrench now.
Thanks
Old Aug 6, 2012 | 07:52 PM
whiskers's Avatar
Yep , it can give you some boo boo's! Seriously though i use a hydraulic jack to push up against the trucks weight. It works.
Old Aug 6, 2012 | 08:22 PM
Truckman's Avatar
Yes ,That is the way to tighten,
Ordered wrench today,Hopefully have it by the weekend, Gettin tired of driving in 4th at 60Mph on the interstate,,
Old Aug 14, 2012 | 06:50 AM
Truckman's Avatar
Hi ALL, Has anyone out there tried one of these yet?
Looks like it could work.
http://fifthgearrepair.com/nv4500repair.html
Old Aug 14, 2012 | 07:29 AM
patdaly's Avatar
I've got one running, a couple others here now. Mine was the fully splined mainshaft and lost it, I guarantee you it won't ever come loose again with this fix unless it manages to twist the 4 tabs off, not much chance of that. The only bad thing is it will only work with the 4X4 units.
Old Aug 14, 2012 | 10:34 AM
mrclean's Avatar
Hi ALL, Has anyone out there tried one of these yet?http://fifthgearrepair.com/nv4500repair.html
I'm running one of those......so far so good. Approx 10k miles on the repair (stock shaft), with @3k miles towing an 8k trailer. No problems as yet......
Old Aug 15, 2012 | 03:39 PM
Truckman's Avatar
Thumbs up Ordered
Just Ordered the retainer, The company (Jeff) told me they made a total of 1100 retainers They have 200 well 199 left, after that they are not making anymore,so if you need one,, GET IT NOW.
We will see how it works,
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
