Pulling my VP44
Old Jan 18, 2010 | 03:22 PM
phal's Avatar
thanks
Originally Posted by johnh
it's a cam position sensor, the crank sensor has been removed....it used to be on the side of the block near the starter motor
Thanks Johnh,
Is it easy to get to if I need to change it in the future?
...gary
Old Jan 19, 2010 | 02:04 AM
Tate's Avatar
Its doable, but awkward. If its working fine, I would leave it.
Old Feb 5, 2010 | 03:54 PM
phal's Avatar
The pump is in but...
I bought the pump from Midwest and installed it last weekend. I did a lot of stuff before putting the lines back in like deconverting it from the run only fuse wire that solved my hot start issue on the old pump.
I was putting the fuel filter back on and noticed that the rubber coated steel washer that seals the banjo bolt had a bigger ID than the original.
I measured the ID of the new washer and it was .25" bigger than the old one. It moved around alot on the shaft and I was not comfortable installing it.
I called Midwest, supposedly talked to a tech, and he said "its the same washer we have always sent with the pumps", I wonder if they really understood what I was talking about. This thing may seal or it may not. I do not want to find out the hard way and have to take it all apart again.
So, I am going ahead and ordering a FP gage kit from Genos and installing. I will also pick up some banjo seals while I am at it.
.....gary
Old Feb 5, 2010 | 04:05 PM
phal's Avatar
just ordered
An IssPro FP Gage and install kit and steering column mount.
I also ordered 6 Cummins washers for the banjo, that takes care of that!
....Gary
Old Feb 14, 2010 | 04:17 PM
phal's Avatar
Truck is Running
Hey Guys,
The truck is running but I have not driven it yet. I idled it for 15 minutes today. I am in the process of installing the fp gage kit.
Going to need Tires and an Exhaust before it is all done.
....gary
Old Feb 22, 2010 | 03:21 PM
phal's Avatar
gage install
Gage install went well, I am putting out 17 psi from the FASS DDRP at idle.
I found out the hard way that my gas tank sending unit is bad. Messed with
the fuel system for some time before I realized that I did not have a 1/4 tank,
I was out of fuel!
.....gm
Erska
17
Mar 6, 2009 09:52 PM
mullercarl
Competition / Pulls / OffRoad
45
Mar 19, 2007 10:10 AM
Smokin'02
Feb 25, 2007 08:39 PM
TerryS
Nov 13, 2006 03:52 PM
Timmay2
25
Feb 12, 2006 01:00 AM
