Puke Bottle Relocation/Mods
Old Mar 1, 2008 | 05:29 PM
GizmoJoe's Avatar
I am tired of the oil on everything and see in member's signatures "Puke Bottle Relocation". What did you do to take care of this? Photos would be great.
Gizmo Joe
Old Mar 2, 2008 | 04:19 AM
Tough Old Goat's Avatar
Gizmo,
Found this, using the handy search thingie in the toolbar:
https://www.dieseltruckresource.com/...ht=puke+bottle
Cheers,Rain.
Old Mar 2, 2008 | 12:33 PM
jrs_dodge_diesel's Avatar
Here's a how to thread I started about the bottle:
https://www.dieseltruckresource.com/...threadid=62155
Old Mar 2, 2008 | 03:02 PM
dozer12216's Avatar
Everyone will do it different. Here is my take.
Got a empty spray paint can and cut top off. Bolted it to frame or bracket in pocket in front of left battery.
Secured three feet of clear reinforced vinyl hose and ran from engine to spray paint can and placed puke bottle in can. Then wrapped some air cleaner foam in top of can to stop oil.
My engine with higher milage and pulling heavy trailer does blow some vapor and still have to clean occasionally. Thought this was better than dropping on ground.
Old Mar 2, 2008 | 05:34 PM
GizmoJoe's Avatar
Thanks for the info...Seems like everyone does this a little different...So did I...
Instead of using a sock, I sewed a black spandex tube about 8" long, doubled it over and slid it over the bottle. I'm hoping that it will let enough vapors out and not to build up pressure while stopping the oil from spraying on everything. Being black, you don't even notice it there like you would a sock.
Not sure if this is my final cure but it took < 5 minutes to do with what I had in the house.
Gizmo Joe
Old Mar 2, 2008 | 08:28 PM
TOM R's Avatar
just looked, my truck has no bottle just goes on the graound and all over the front of the engine, thought I has a leaking front seal, glad it is this, I was also wondering why i smelled oil/fuel alot, looks like my rad has been replaced guess i know what i am doin tommorow
paparcl
17
Sep 20, 2006 12:33 AM
J BODY
15
Sep 8, 2005 08:12 PM
TPilaske
Jan 10, 2003 09:07 AM
