Problems on my camping trip...
Old Aug 30, 2003 | 06:54 AM
AlpineRAM's Avatar
Re:Problems on my camping trip...
Jack, it should be the VSS in the rear axle or the cables and connectors for it. Naturally the cruise can't work if it's got no speed input, and the rear wheel ABS feels a little lost too. I'd try and swap the sensor ( really not much work, not too pricey too) and see what happens. Or just pull and clean it, if there's metal debris on it, which would make it miss seeing the teeth of the tone wheel.
Good luck, and I hope you'll be a happy camper soon again ;D
AlpineRAM
Old Aug 30, 2003 | 07:50 AM
AlpineRAM's Avatar
I don't think you'll need a dealer to do the first check: simply get under the truck, locate rear differential ;D (hard task on the 2WD ) and look for the only electric cable going to it. Voila, the VSS. You'll have to remove the bolt that attaches the sensor, the sensor shield and the brake line.Pull out the sensor and disconnect cable. Clean sensor and oil O-ring lighly, reinstall sensor, shield, bolt (torque 24Nm or 18 ftlbs, put brake line holder on the stud, put on the nut.
If not too corroded all this can be done within about 30 minutes on the side of the road.
I'd suggest that you try this ASAP because due to this failure your rear wheel ALB can't work and this can be extremely bad news with a camper.
Have a nice holyday
AlpineRAM
Old Aug 30, 2003 | 12:09 PM
phox_mulder's Avatar
Isn't there also a sensor on the transmission somewhere?
When I installed my truespeed (speedometer correction) the instructions said to tap into the wires coming off the transmision going into the ABS controller.
Tapped in right at the ABS controller, so I don't know where those wires actually went to.
phox
Old Aug 31, 2003 | 12:36 PM
ARAcummins's Avatar
never fails something always happens on the weekend when your going somewhere, couldn't happen on the way to work or something or inlaws. Oh well at least its not real major and you made it to where you going. Good luck on the way home Heath
Old Aug 31, 2003 | 03:40 PM
Dieseldude4x4's Avatar
I replaced the rear snesor but the lights are still on.
I finally got the Cummins Quick Check II but all I got to do is figure out how to use it.
Richie O
Aug 23, 2011 08:50 PM
jmccart
Mar 10, 2008 12:30 PM
06GrayCTD
Aug 27, 2007 04:16 PM
Pop-Pop
Apr 23, 2006 03:33 PM
jthorpe
Oct 24, 2004 01:50 PM
