Problem with front axel locking in
Old Nov 25, 2009 | 03:44 PM
Vanb's Avatar
I have a 1999 2500 ton with a dana 65 front axel. The problem I am Having is when I put it into 4 wheel drive the it seems to be fine but when i turn the wheels eather right or left it binds up. I replaced the air lines that were cracked and this didn't seem to help. I was wondering if it is the actuater motor that is messed up. I would appriciate any help. Thanks
Old Nov 25, 2009 | 04:02 PM
DodgenIt's Avatar
What kind of terrain are you binding up on?
If its dry cement, hard dirt of anything like that, its totally normal.
In 4 hi or low you either need to be going straight or in a terrain that allows the tires to turn/slip seperatly.. or you will get that binding affect like something is about to break.
Old Nov 25, 2009 | 04:14 PM
Vanb's Avatar
It has happened in the dirt and in the snow. It seems that the front end isn't completely splined together.
Old Nov 25, 2009 | 09:53 PM
dozer12216's Avatar
Inspect front axle U joints.
Old Nov 26, 2009 | 02:14 PM
SIXSLUG's Avatar
Even in slippery and dirt road conditons mine will tend to walk a little when turning hard. I try not to turn the wheels all the way to lock when I am in 4x4 just to go easy on the parts.
If you have replaced the vacuum lines to the actuator and your 4WD light comes on you should be locked in. A good shop should be able to tell you if your 4x4 is working correctly also.
Kurt
Old Nov 26, 2009 | 10:23 PM
Vanb's Avatar
Thanks for all the help. I am headed for the mountains this weekend I will report back.
xp8103
Dec 25, 2005 09:45 AM
boostedte37
Apr 5, 2005 08:18 PM
Gypsyman
18
Oct 2, 2004 11:59 PM
rangerst
Feb 1, 2004 12:41 AM
JImbo1
Apr 9, 2003 07:46 AM
