power surges
Old Sep 25, 2008 | 08:55 PM
roadrage1's Avatar
power surges
my dads 2000 3500 in the last month has started these surges on and off droping 100-150 rpm, its got 148000 ml does something need ajusted or what?
Old Sep 26, 2008 | 04:51 PM
dozer12216's Avatar
Check lift pump pressure immediatelly. Replace lift pump if below 5 PSI. Get ready to replace VP44 in near future in all probability. Check for codes by cycling ign key on three times. Read in odometer and report.
Old Sep 26, 2008 | 07:32 PM
roadrage1's Avatar
thanks for your help. the code said p-done, so if you know what that is please tell, thanks
Old Sep 26, 2008 | 07:56 PM
Junk Man's Avatar
Go to ORilley's & use their scanner. Codes don't always show with the key. Autozone & Advance also loan scanners but theirs wouldn't reset codes last time I checked. Do you have gauges?
Old Sep 26, 2008 | 10:09 PM
WestTN's Avatar
It is possible your IAT sensor is dirty or failing. The grid heaters draw enough current to affectr the tach reading when they cycle.
tyschr
Aug 3, 2010 01:35 PM
raider
Dec 22, 2006 07:27 PM
sootin762
Apr 9, 2006 06:12 PM
mamajo
Jan 21, 2005 08:35 PM
GearedUp
Oct 26, 2004 09:01 PM
