Power steering pump problem
Old Feb 25, 2006 | 04:59 PM
Pike's Avatar
Yesterday, my ps pump puked fluid out the top rather than turning the wheels. It has done this twice (once last winter), usually when I don't have time to let it warm up for very long. It also groans in colder weather. Will synthetic fix this? How do I change the oil, and which oil is best to use? I am in Vermont, and the temps can be from -40 to 100. Thanks
Old Feb 25, 2006 | 05:02 PM
plow's Avatar
there was somebody else on here that had that problem and I believe it was the accumulater that was causing this.
Old Feb 26, 2006 | 06:19 AM
AlpineRAM's Avatar
https://www.dieseltruckresource.com/...ad.php?t=92310
HTH
AlpineRAM
Old Feb 26, 2006 | 06:55 AM
Pike's Avatar
Thanks guys, I will check that out. My brakes make a little noise when I step on them when it is cold, same noise the ps pump makes, so maybe it is the accumulator. Hope I can fix it for less than 600 I will probably change the ps fluid too. Thanks a lot
tony99
Apr 9, 2014 08:25 AM
DodgeRamdiese01
Jun 19, 2009 12:13 AM
bamadzl
26
Mar 16, 2009 02:22 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
amartinson
0
May 4, 2003 01:55 PM
