power steering pump leaks - need advice.
When I started the truck this morning I heard a groaning from the steering like during the winter.. it was around 60 this morning... by the time I got to work it had gone away. When I got home I checked my power steering fluid and had very little... I just topped it of less than a month ago with STP steering fluid (all I could find at when I needed it). I then proceeded to clean the top of the power steering pump. Started the engine and wah lah... I have a leak in the top of my power steering pump. , right at the center bolt. Could this be caused by using STP steering fluid and if so what should I use to replace it? Secondly if this is not caused by the fluid what are my options? I have about 90,000 miles and hope that this is covered under the 100,000-mile warranty? Does anybody know? If not, what should I be looking at to fix it? Does anybody have a drawing/schematic of the pump - I couldn't really see down there so well but could definitely tell it was coming from the bolt in the center. This is the 2nd time in a month I have added fluid, but only the third or fourth time since I bought the truck new.
they have problems with the vacume pump leaking which is what the power steering pump hooks to,the seal between them leak and someitmes looks like the power steering is leaking,but being your truck was low on fluid id look to see wheather the pump is leaking at a line or at the pump,the pumps are not all that expensive and if the thing doesnt grown when it is full then it is probably working correct and doesnt need to be changed unless the pump itself is leaking,to change the pump you will need a bent wrench to get to the one bolt in the back a lil easier,wrench that looks like a C they work best,pumps not that expensive if thats the problem,as far as warranty no such luck,cummins waranty covers the engine all the bolted on stuff from dodge is our problem kinda sucks,if you cant figure it out i can fax you some papers with the instruction you need,good luck
Mine is leaking too it looks like there is oil in it too? Could it be the fan blowing the oil from the blow by back? Mine power steering was very low also but this seems to be an oil leak. I think there is an oil line running in the power steering pump or vaccum pump not sure which?
my seal leaked to i have the extended warranty and they (dc) fixed it. a friend went in today to dc with 27k on his 02 and got it from smith in idaho the local dc changed his fluid and said goodbye we can't fix it,nothing wrong.said something about a tsb on the fluid
Re: power steering pump leaks - need advice.
The parts store has a reseal kit for them that contains all the seals for the pump.
you wouldn't happen to know the number and or name of the parts kit would you?
justagoodolboy
09-07-2022 12:43 PM
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
