power steering pump
Old Jan 1, 2010 | 04:25 AM
x1phats10x's Avatar
power steering pump
wanted to know if the power steering pump goin out would cause the abs light to come on. havent had time to go to the dealer to have the computer scanned
Old Jan 1, 2010 | 07:07 AM
jrs_dodge_diesel's Avatar
Not likely. If the pump went out your brake pedal and your steering wheel would be really tough to use.
ABS light can be a number of things. Bad sensor, gunked up tone ring, the brake valve assembly under the master cylinder.
Old Jan 1, 2010 | 10:12 AM
Junk Man's Avatar
Likely abs sensor. Any of the parts stores will loan/rent a scanner. No need to involve the dealer.
Old Jan 1, 2010 | 06:32 PM
DodgeRamdiese01's Avatar
you would certainly know if your pump went out, it willl be un drivable, mine went out over the summer and it took every ounce of strength i had to just park the truck to wait for a tow.
Old Jan 1, 2010 | 06:41 PM
x1phats10x's Avatar
thanks for the info. i jus started noticing that when i was sittin still i cant turn the wheel lock to lock without moving forward or backward
Old Jan 1, 2010 | 06:56 PM
hmmm it may be on its way out them mine shattered and pieces of the gear were lodged in the pump not allowing it to work at all, as I said real fun. I ended up replacing the pump steering box and lines not cheap
tony99
Apr 9, 2014 08:25 AM
DodgeCowboy
Aug 28, 2006 08:57 PM
powerwagon440
May 25, 2003 02:31 PM
amartinson
0
May 4, 2003 01:55 PM
