power steering pop
Old Apr 20, 2010 | 08:38 AM
coon-dog7070's Avatar
power steering pop
over the past 2 weeks ive noticed a little pop that sounds and feels like its comin from right under my feet when im driving. It does it when i turn either to the right or to the left. Any ideas on what's causing this or what the problem could be?
Matt
Old Apr 20, 2010 | 11:31 AM
ado2b1's Avatar
Suspension bits and pieces. My guess would be tie-rod or ball joints. Have someone check out underneath while you move the wheel back and forth. When you see slop in a joint, that's the place to start.
Old Apr 22, 2010 | 09:09 AM
i have been stumped on this because im not feeling anything in the steering column, and when i hear and feel it its like its comin from right under my feet where the drag links are
Old Apr 22, 2010 | 04:12 PM
650HP-CTD's Avatar
Matt
I'd bet $100 your track bar is shot. I had the same issues....had Dodge troubleshoot it only to convince me to replace the intermediate steering shaft as there was a TSB for it on the '02 2500. Picked the truck up after paying the *********** to replace the steering shaft only to have the same issue.
I stopped by Napa and an old dude there behind the counter said "Ever replaced your track bar"? I lifted the truck up and using a bar, had almost 1/2" of play in the ball joint on the end of the track bar.
$277 later and a new Napa track bar solved my issue. That one wore out 45k miles later and now i'm looking at replacing the '98.5-'02 ball joint style with the '03 style:
I'm ordering one of these:
http://www.sourceautomotive.biz/shop...Kit-54-20.html
And one of these:
http://www.sourceautomotive.biz/shop...Bar-56-20.html
Also, check your inner and outer tie rod ends for any slop (lift up the truck to do this). There is a outside chance your issue is related to a tie rod end, but they don't usually make a knock sound, just give sloppy steering and excessive tire wear when they are worn.
--Sk
bataradena
Jan 31, 2011 10:03 PM
dieselJon
Nov 21, 2007 05:53 PM
973604x4
Sep 4, 2007 08:18 PM
kawi600
Sep 15, 2006 04:36 PM
Sevir
Nov 9, 2005 10:21 AM
