Power loss
Old Apr 10, 2006 | 03:30 PM
aintnohemi's Avatar
Power loss
My 99 when I crowd it at about 70 mph loses all power and when I push in the clutch and let it go back to idle it will pick up and go on. It is getting worse and i wondered if anyone might know if it may be fuel or maybe my wastegate dumping prematurely. Just would like to know where to start. Thanks
Old Apr 12, 2006 | 06:40 AM
Kimrey's Avatar
check the codes in the truck first. You can do this by turning the ignition switch on and off ( without cranking the truck ) 3 times and look at your odometer and it will show you any codes the computer has thrown.
Kimrey
Old Apr 12, 2006 | 06:48 AM
graphitecumnz's Avatar
key check doesn't work on a 99.
Symptoms sound like a dead/dying injection pump.
Old Apr 12, 2006 | 07:07 AM
Truckman's Avatar
Talking Apps
You say Looses ALL power,,, Engine shuts off??? Or It goes to Idle?? Dont touch the go pedal for 10 seconds Then all works OK???
Sounds Just like mine,, I replaced APPS all set now..Got a use one on ebay for $52.00. If you have a standard you CAN use an automatic's APPS but Not Visa versa,,,I have pics in my gallery to show the difference..
What does it mean to CROWD it??
Old Apr 12, 2006 | 09:52 AM
high country's Avatar
does it belch any smoke? I would try an apps reset before I bought any parts. there is a procedure for resetting the apps that would be wort a try, search for apps on here.
Old Apr 12, 2006 | 09:57 PM
aintnohemi's Avatar
does not smoke just loses all power. Motor seems to be running fine just loses power and when i push in clutch and let it go to idle just for a second, when i let out the clutch it will run as if nothing is wrong
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
Ranger 2/75
Mar 16, 2006 05:07 PM
jdcott1
Oct 20, 2002 11:48 PM
