Power Loss
Power Loss
I have lost power & have increased EGT's. Where I normally would have about 400 to 500 degrees at normal driving, I am now running 600 almost instantaneously to 1000 quickly. This is all with my comp set on level 2. It has never done this before. I have never been user friendly to my Turbo. I have 250K pretty tough miles on my truck. Does the loss of power & high egt's sound like a turbo issue. Also when I go to level 3 or higher, or tow at all, my truck kinda skips & misses. It just jerks & all. I t is hard to pinpoint what is causing it. I knbow when towing, I can turn the Edge off & it quits. Can you guys help me out with any of this mess? I am considering trying one of the AIRWORKS turbos. Does anyone have any experience with this turbo? Thanks a million!!
How is power and EGT's, not towing, with Edge Comp off? Based on your towing experience, doesn't it sound like a mafunctioning box?
"I know when towing, I can turn the edge off and it quits" "It" being the problem quits?
RJ
RJ
I have lost some boost, probably 5 lbs or so. When I really get on it at level 5, I hear a shrilling sound that I think is coming from the turbo. I have another problem that I discovered today. I couldn't tell if I was leaking fuel or transmission fluid, just saw red substance on the ground. Now, I will let yall figure out why I wasn't sure which it was. Anyway I found the tranny lines leaking where they were laying on a crossmember right next to the front driver's side of the oil pan. It looks like there should be some kind of bracket there to hold them in place. I am ordering 2 new lines, though only one is leaking. Both have been rubbed. How difficult are these to change out At the intercooler? Thanks.
RHC
Aug 12, 2019 03:32 PM
Ranger 2/75
Mar 16, 2006 05:07 PM
