power loss
Old Apr 29, 2008 | 09:04 PM
stevenl's Avatar
power loss
ok so i have a 2001 dodge with a HO cummins and a six speed. i have a edge comp on it, intake and exhuast. recently my truck has just felt like it has no power. when ever i try to get on it and really hammer the throttle it seems like it takes forever to start picking up speed, and when i shift into the next gear it feels like the truck is just bogging down and sounds like its under a huge load. this is getting prgressivly worse. for expample ill be going along in 2 gear and floor it and it will kinda take its time grain rpm. theni shift into thrid and the truck slows way down again before the boost kicks in and it picks up speed again, but it takes forever to hit the boost. what could this be. i have good fuel pressure, and just put a new life pump in a few months back. i know this is a long thred but any help and suggestions wold help. thank you
Old Apr 29, 2008 | 09:43 PM
blackdiesel's Avatar
Registered
Welcome to DTR. Check for codes, key on, off, on, off, then on, and watch your odometer. Sounds like you have a dieing Injector pump. 0216 will verify it.
Old Apr 29, 2008 | 09:52 PM
stevenl's Avatar
thanks for the welcoming.... adn thats why i am think unfortunatly. and i have checked my codes just a 1693 which i belive is nothing to worry about. and if it is my injection pump. when i replace it should i go with a stadnard output pump? i hear that a SO pump combined with the comp box will give me more power than my HO pump
Old Apr 29, 2008 | 10:15 PM
dj_souvlaki's Avatar
hows your fuel preassure?
Old Apr 29, 2008 | 10:30 PM
Registered
If you have a 1693, then theres another code there also that it's not telling you, (not uncommon) you will have to use a code reader, autozone will pull it for free(probable others also)
Old Apr 30, 2008 | 09:21 AM
stevenl's Avatar
i have good fuel pressure. 15 psi at idle and it never drops below 7-8 when i floor it.
Old May 5, 2008 | 01:45 PM
stevenl's Avatar
is it possible that this problem could be a faulty MAP sensor
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
Ranger 2/75
Mar 16, 2006 05:07 PM
jdcott1
Oct 20, 2002 11:48 PM
