Front Axle Leak
Old May 5, 2008 | 01:03 AM
ceyl's Avatar
Front Axle Leak
After alot of searching and educating myself in these forums, I replaced my front wheel hub assembly. Now I have a gear oil leak on that axle. I don't remember seeing a seal that I should have replaced. Any advice or recommendations to stop this leak?
Old May 5, 2008 | 07:24 PM
mini14's Avatar
they might just be weeping a little and it might stop, just keep an eye on fluid level. if not then be prepared to do the job all over again along with pulling the carrier.....dont forget to lube the axle shaft ends with some grease before insertion.....when doing the hubs if u caught some sand on the shaft ends which is common u might have wiped out the seal, its not easy to insert them perfectly centered.
Old May 5, 2008 | 09:33 PM
ceyl's Avatar
Thanks, I should have waited awhile before asking, after I drove it to work and home again it seems to have stopped.
rustydeeretech
17
May 21, 2011 03:05 PM
mr T
Sep 1, 2005 02:13 PM
DRESSER DAVE
Apr 11, 2005 06:11 PM
Paul Winey
Jun 22, 2004 08:09 AM
moparlvr
Jan 23, 2004 09:40 PM
