front axle leak
Old Apr 9, 2005 | 05:34 PM
DRESSER DAVE's Avatar
front axle leak
I got a drivers side axle leak,I know I have read this fix is a pain in the butt,but has anyone done them and if so any tricks I should know about?
Old Apr 9, 2005 | 06:37 PM
infidel's Avatar
Biggest trick is to wait if there has been any front end work done recently or the differental is over filled to more than 3/4" below the fill hole. Most leaks will stop by 500 miles or so after the work has been done or after the the fluid is at the correct level.
Here's a recent thread that should help https://www.dieseltruckresource.com/...threadid=65667
Old Apr 9, 2005 | 07:06 PM
seal
thanks Infidel,no work for about 20-25k miles or fluid change or adding
Old Apr 11, 2005 | 05:14 PM
PistolWhipt's Avatar
Seals are shot. Mine is doing the same thing. Looks like quite a job. Good luck.
PISTOL
Old Apr 11, 2005 | 06:11 PM
infidel's Avatar
Might want to check with your dealer and see what they want to do the seals.
It used to be rated at $125, well worth it.
rustydeeretech
17
May 21, 2011 03:05 PM
mr T
Sep 17, 2005 05:31 PM
mr T
Sep 1, 2005 02:13 PM
Paul Winey
Jun 22, 2004 08:09 AM
moparlvr
Jan 23, 2004 09:40 PM
