PM3 probs
Old Mar 13, 2004 | 02:06 PM
Gman77's Avatar
PM3 probs
Installed PM3. Truck now shudders and bucks under acceleration. I have soldered the pump wire and ground wire, and rechecked MAP connections. Any suggestions before I call Rod?
Old Mar 13, 2004 | 03:25 PM
AlpineRAM's Avatar
What does your fuel pressure say? Is it an auto-if yes which mods?
AlpineRAM
Old Mar 14, 2004 | 05:13 AM
Gman77's Avatar
5 spd. It's getting around 9-10 lbs under throttle. 14lbs idle.
Old Mar 14, 2004 | 08:24 AM
AlpineRAM's Avatar
Sounds OK so far- have you checked for codes? Does it buck under full load only or does it start bucking when rolling on the pedal and stop bucking when you are running WOT ?
AlpineRAM
Old Mar 14, 2004 | 09:08 AM
Gman77's Avatar
Starts as rolling on throttle. Haven't got WOT yet because she is so rough. Have not check for codes. My year only can be done at the shop.
Old Mar 14, 2004 | 11:38 AM
AlpineRAM's Avatar
I got rid of my last stumbles and buckings by replacing the quck connect fitting on the tank with a rubber hose. I had fine air bubbles in the fuel. On stock power this wasn't noticeable but with the ponies on steroids consumption got big enough that the air in the fuel got a nuisance.
You can read https://www.dieseltruckresource.com/...threadid=40822
about it.
AlpineRAM
Old Mar 14, 2004 | 04:37 PM
Haulin_in_Dixie's Avatar
about it.
AlpineRAM
Interesting, I have been considering just that change, glad you posted it.
Old Mar 15, 2004 | 07:18 AM
Gman77's Avatar
Angry
Well this morning after pulling out of the coffee stop, the truck died. Coasted off to the side and cranked. Nothing. Turned box off, waited a minute or so and she fired up and seemed fine all the way to work.
Old Mar 15, 2004 | 10:26 AM
AlpineRAM's Avatar
Gman: I think it's time to call Rod.(I have very good experience with his product support!) It might be a faulty box, or some trouble in the wiring harness. I'd say that a brief visit to autozone or the like to get codes checked could prove worthwhile.
Good Luck!
AlpineRAM
Old Mar 15, 2004 | 02:39 PM
Gman77's Avatar
Talked with Rod. Box'll be sent back.
Old Mar 15, 2004 | 03:01 PM
AlpineRAM's Avatar
Try to get your codes checked nevertheless. Maybe there's some other problem hidden somewhere that did surface because of the box. I think that reading codes should be part of the regular maintenance. I do go a little further and take tha truck for a spin with the obd2 tester attached and plot various sensor outputs- helped me a lot to find some small stuff going bad- like IAT (connector corroded- there was no rubber gasket in the plug) andsome others.
AlpineRAM
Old Mar 15, 2004 | 04:57 PM
BigBlue's Avatar
I replaced the stock supply line with -8 braided line from the tank all the way to the injection pump. I think I need to tighten the clamp on it again just to make sure.
blackdiesel
34
Aug 2, 2006 08:41 PM
Diesel Freak
Mar 27, 2003 11:30 AM
Dusty 96
Dec 12, 2002 10:00 PM
scottrod
17
Nov 3, 2002 07:32 PM
