plz help!!!!!!!!!!!!!
Old May 19, 2012 | 05:16 PM
92vinny92's Avatar
Exclamation
alright ill go check all that stuff but now i have a slight knock from either the valve or rocker arm any suggestions there? also why would it idle and rev up fine but then have fueling issues when under a load. also when i start it and rev up it the motor sound like its missing until the truck warms up??
Old May 19, 2012 | 06:53 PM
rickf's Avatar
If you had the head off you have to check the valve clearances. One tight valve could screw up the whole thing. I would start there. If the head gasket is no more than a couple of thousandths thinner then you will have many tight valves!
Rick
Old May 20, 2012 | 11:10 AM
SIXSLUG's Avatar
If you have an out of adjustment valve to the short end it won't let the proper amount of air into the cylinder during the intake stroke, kind of like just cracking the faucet on the sink, the pressure is the same, the flow is reduced.
If its too open you get too much air and can lean mix the power stroke and /or hit the top of the piston.
Hearing a knock may be easier by placing a long screw driver against the rocker cover and the handle end to your ear. I can never tell if its the vp clatter I am hearing.
Many things come into play during a head gasket r/r on these. Backstep each event to see if you missed anything.
rolling18
Jul 12, 2006 12:19 PM
Arkangel77
Jan 8, 2006 12:00 PM
12valve
30
Dec 25, 2005 10:01 AM
taildragger
Oct 23, 2005 10:56 PM
storx
Jul 22, 2005 06:12 AM
