Piston cooling nozzles - crankshaft bearings
Old Apr 16, 2009 | 11:16 AM
wyomingcowboy's Avatar
When installing the new crank bearings I notice that the holes in the bearing don't line up exactly with the holes for the cooling nozzles. I actually noticed that the ones I took out don't line up that great either. Is this normal? Am I just getting paranoid about things or do I have a genuine concern?
TIA
Old Apr 16, 2009 | 11:29 AM
dozer12216's Avatar
No concern. Look carefully at oil flow diagram and will understand.
Old Apr 16, 2009 | 11:54 AM
SIXSLUG's Avatar
The holes are offset to keep oil pressure up and cause oil smear. If they aligned the oil would take the easiest route thru the openings and not build pressure and squeeze thru into the bearing surfaces to lube the journals.
Kurt
Old Apr 16, 2009 | 01:18 PM
Got ya, thanks guys!
Alec
Feb 7, 2014 09:38 AM
Dualler
Jul 31, 2005 02:36 PM
Dualler
Jul 11, 2005 09:40 PM
jrs_dodge_diesel
Feb 1, 2005 02:42 AM
mopar2ya
Apr 1, 2004 06:42 AM
