Performance Injectors and FP?
Old May 8, 2008 | 01:45 AM
1BAD4X4's Avatar
Quick question that believe it or not, I hadn't really thought of until the past few days. Do performance injectors effect fuel pressure? If so, how or why?
Not sure if this is a "Duh!" type answer, but when you don't know... you don't know. It seems like they would, because they are putting more fuel in, but...
Old May 8, 2008 | 08:02 AM
91rangerturbo's Avatar
Nope. Not unless your already not getting enough fuel pressure. Mine truck with stock injectors i could draw it down the same amount as i can with large injectors 150hp sticks.
Old May 8, 2008 | 10:49 AM
Mopar1973man's Avatar
MINIMUM FUEL PRESSURE on a 2nd Gen 24V is 10 PSI - PERIOD!
So if you large injectors are drawing pressure below 10 PSI it WILL cause damage to the VP44 (Injection pump)
Old May 8, 2008 | 09:52 PM
1BAD4X4's Avatar
I know about the minimum pressure needs, but I'm wondering if the larger injectors will directly cause a drop in fuel pressure wether it be during idle or WOT... or any where in between.
Old Jun 6, 2008 | 08:52 PM
jaws136's Avatar
Mopar man that is really what i've been looking to see for a long time now. I've been reading over 5 is fine and unknowingly runnin down my VP i'm pretty steady at 7 once it warms up, is that because it thins out when the fuel warms? It's a bit higher with cold motor.
kawi600
Mar 11, 2008 07:28 PM
nmf
Nov 25, 2007 11:59 PM
KRB
May 20, 2007 06:20 PM
Redline Ram
Feb 27, 2007 08:02 PM
BIGOKIE
Jul 21, 2004 05:53 PM
