Part # on Overflow Valve?
Old May 5, 2005 | 05:32 PM
Flatty's Avatar
I am going to getone of these in hopes that I don't have to change out my injector pump. Who has a part # on this?
Thanks
DIma
Old May 5, 2005 | 10:25 PM
bmoeller's Avatar
Does a VP-44 on the 24 valve even have one? The P7100 on the 12 valve engines have one.
Old May 5, 2005 | 10:44 PM
Dr. Evil's Avatar
yep......#12:
http://www.dodgeram.org/tech/dsl/mt_...l_sys_comp.htm
Sorry I cant help ya on the p/n
Old May 6, 2005 | 09:27 AM
infidel's Avatar
Wonder how many 24 valvers have been replacing lift pumps when the problem is really the overflow valve?
On a 12 valve the overflow valve is probably the single most componet that fails over time.
Old May 6, 2005 | 10:01 AM
darrenG's Avatar
if it is the over-flow valve that goes bad, how come when the lp is replaced it fuel pressure is back to what it should be?
Old May 6, 2005 | 10:28 AM
Dr. Evil's Avatar
The lift pump is a seperate problem alltogether.
The question is, how many VP-44's are being replaced without considering that the overflow valve could be the problem....
Old May 6, 2005 | 10:31 AM
darrenG's Avatar
aside from the lp, vp and overflow valve, what else along the fuel line alone fails regularly?
Old May 6, 2005 | 10:38 AM
Flatty's Avatar
Well I can't get the part from anyone. Every dealer I call says the part is a piece in the VP44 and can't be replaced alone. Does anyone ahve the connection at a dealer that would know what the aprt is?
Thanks
Dima
Old May 6, 2005 | 12:14 PM
RAM2940's Avatar
Is the overflow valve part of the banjo bolt, or is it mounted/inserted behind the bolt.
And is it on all vp-44's or just certain years.
Old May 6, 2005 | 12:26 PM
Flatty's Avatar
All VP44's. I found one for a BANGING deal.
http://www.o-f-i.com/index.php?pid=1...T_PIPES_&_KITS
The place seems to be pretty good.
Dima
Old May 6, 2005 | 03:17 PM
Dr. Evil's Avatar
good find....for what it costs its sure worth a shot at replacing the OF valve rather than spending major chingo on a VP-44
Old May 6, 2005 | 08:11 PM
JAFAW's Avatar
the number is 1 467 445 003 it is a bosch number most good fuel shops should
have it but i think your off on thinking that the overflow valve is a problem. The open about 7psi or maybe a little higher
Old May 7, 2005 | 01:08 AM
J BODY's Avatar
It will not fix your truck and you will buy a VP-44.....you heard it here first. (assuming you have tested the rest of your fuel system as suggested in your other post).
Old May 7, 2005 | 07:41 AM
Dr. Evil's Avatar
Thanks for clearing that up J Body
Old May 7, 2005 | 09:51 AM
J BODY's Avatar
Thats my story and I'm sticking to it!
