Oil Pressure Sender correct P/N?
Old Aug 10, 2007 | 03:45 PM
jvanick's Avatar
Ok, I did a bunch of searching here and i can't figure out exactly what oil pressure sender unit I need.
I found:
Cummins p/n: 4921511
or
Cummins p/n: 4088390
This is going in a 2001 24v
I'm reading 0psi oil pressure, which, since I drove back about 15 or 20 miles with it like that, pretty sure that there's nothing wrong with the oil pump.
Also... should I just order from schied? Or is there someplace else to get it from?
Thanks!
-J
Old Aug 13, 2007 | 08:06 AM
jvanick's Avatar
Anybody?
I'd really like to order one today.
-J
Old Aug 13, 2007 | 07:18 PM
SuperDiesel's Avatar
I hope you get the help you need. My truck this weekend acted up also. I was cruising at 65 when all of a sudden, the oil pressure gauge went down to 0. I immediately pulled over and checked the oil. It was full, and the truck never did run hot. I believe I have the same problem as you, so I will call Cummins to find out which is the correct part number.
Old Aug 13, 2007 | 07:20 PM
pind's Avatar
If my recall is working, 4921511 supercedes 4088390. It was somewhat of a runaround with the local cummins dealer, but we eventually worked it out. Turns out they are the same part.
Old Aug 14, 2007 | 11:06 AM
jvanick's Avatar
I found one on www.mydodgeparts.com
$71
part number: 5012991-AB
I ordered it, hopefully it's the right one... otherwise I'll be ordering the cummins one.
-J
Old Aug 15, 2007 | 08:46 AM
jvanick's Avatar
they canceled my order due to the part number being incorrect? Even tho it's showing on their catalog.
so I ordered the cummins one from scheid diesel.
-J
Old Aug 17, 2007 | 12:34 PM
jvanick's Avatar
Got the new sensor and installed it... all of about 20 or so minutes of work...
everything is working perfectly once again.
this forum saved the day again for me... I don't even want to think what the repair would have cost at the ***********.
-J
Tommy93w350
Feb 19, 2008 07:39 PM
wcbcruzer
May 18, 2005 03:26 PM
turboram
Feb 18, 2005 10:33 AM
