Oil leak ?
Old Oct 9, 2004 | 08:40 PM
linetrash75's Avatar
Oil leak ?
I got an oil leak on the front of my engine some where around the power steering pump not real bad about 2 qts 7000 miles. I know its not my blowby that has already been taken care of. Just want some advise on what gasket it might be, without taking apart to diagnose.
Jed
Old Oct 9, 2004 | 08:59 PM
Scubasteve's Avatar
That would be the vacuum pump seal going for a poop.
You can get the seal kit from the chrysler dealer for around 60 bucks and put it in yourself.
When I did mine I found it 10 times easier to pull the vacuum pump and the power steering pump as a unit, made it much easier to line things up when you went to put it all back together.
If you do a search for Vacuum pump seal you will find a few threads on this subject.
Good Luck
Jason
Old Oct 10, 2004 | 11:19 AM
Dr. Evil's Avatar
This will likely cure your problem - should probably be done either way:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Oct 10, 2004 | 03:41 PM
Thanks guys I'll give that a try.
Jed
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
