oil leak
Old Nov 11, 2003 | 03:22 PM
dansdodgediesel's Avatar
oil leak
Hi, I have a 99 dodge diesel, I have an oil leak somewere by the power steering pump. It's leaking engine oil. Does anybody know what normally leaks on this. Is it the oil seal on the shaft the drives the steering pump or just a gasket bad. I just would like to know before i go rippen it apart so i have everything i need.
thanks
dan
Old Nov 11, 2003 | 03:24 PM
Dr. Evil's Avatar
Re:oil leak
Are you sure its not your blow-by bottle thats full??
Old Nov 11, 2003 | 03:33 PM
Haulin_in_Dixie's Avatar
Re:oil leak
I also have a bad leak at the pump. From what I understand from threads, the seal on the vacumme pump shaft and the power steering pump goes bad. Do a search there are several threads on this site about it.
Old Nov 13, 2003 | 04:34 PM
Re:oil leak
were is this blow bye bottle? I see the tub,, some oil is coming out of it. Can't see the bottle.
thanks
Old Nov 13, 2003 | 05:10 PM
waam's Avatar
Lest we forget
Re:oil leak
Yours might not have a bottle, on my 02 it's on the left front end of the engine. Black plastic bottle with four holes in it near the top. So when it gets to full of rain water and blow by oil and comes out of the holes, the fan will blow it all over the left side of your engine. Very bad design I think. The engineers must have been drinking the day they thought of putting the bottle where it is. Their sure is room for improvement in that area. I taped my bottom two side holes shut so the fan would not pick up the blow by film so much.
Waam Holland, Mich
Old Nov 13, 2003 | 05:27 PM
quantrill88's Avatar
Re:oil leak
my blow-by bottle pukes all over the front axle and bottom of engine. been told that how bad it is can depend on the type of oil used.
Old Nov 13, 2003 | 06:33 PM
Re:oil leak
thanks, looks like i don't have one. i see the blow bye tube, but no bottle.
dan
Old Nov 14, 2003 | 11:53 AM
DRESSER DAVE's Avatar
Re:oil leak
Dan
Check out the other posts on this p/s vacuum pump leak,seal and o ring are available through Napa,part # are given in the threads,June 27,2003 ps leak,has all the info you will need,just had mine done on my 2000 CTD
Old Nov 14, 2003 | 04:56 PM
Re:oil leak
thanks guys for you help.
dan
Old Nov 16, 2003 | 02:51 PM
Re:oil leak
I put a new seal in today. took about a hour and half. Hope it works out. Thanks for your help everybody.
Dan
Old Nov 16, 2003 | 07:45 PM
Re:oil leak
[quote author=DRESSER DAVE link=board=4;threadid=22300;start=0#msg209652 date=1068832426]
Dan
[/quote]
How do you get the search engine to go back past September? Tried every key word I can think of and it always ends around September.
Old Nov 16, 2003 | 08:01 PM
amartinson's Avatar
Re:oil leak
[quote author=dansdodgediesel link=board=4;threadid=22300;start=0#msg210249 date=1069015869]
Dan
[/quote]
I hope just the seal takes care of your oil leak. On mine, I had to replace the O-ring also to cure the leak. Sorry I didn't get to reply sooner to tell you about the O-ring. It's definately a "do it as long as you are in there item". Good Luck.
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
