Oil Leak
Old Dec 25, 2009 | 11:14 AM
scook6's Avatar
Oil Leak
I have a new leak coming from the front of the engine. Mine is an 02 with 160,000 miles. I have owned it since new. It is not the puke bottle, it appears to be located somewhere around the water pump. It is oil and not antifreeze. I know it's a shot in the dark, but any help would be appreciated.
Old Dec 25, 2009 | 05:57 PM
rebal's Avatar
might of had a timing cover bolt or a dowl pin come out .check the timing case for a crack
or maybe the oil cooler gasket?
Old Dec 25, 2009 | 10:17 PM
johnh's Avatar
above and a little to the right is the oil filter....need i say more?
Old Dec 26, 2009 | 12:02 PM
scook6's Avatar
It is not coming from the oil filter. It appears possibly to be coming from behind the fan pulley.
Old Dec 26, 2009 | 12:27 PM
torquefan's Avatar
It's quite possible a piece of the gasket blew out between the gear housing and the block. Seen them do it right there before. As mentioned, the other possibility is that a bolt or dowel pin came loose inside the geartrain and was ejected through the housing. That exact location is also the common place for that type of damage to occur.
The first step to diagnosis would be to remove the fan and its mount, and have a look. Clean the oil from the area with brake cleaner and blow it dry with compressed air and hopefully you will see the problem. To pinpoint an exact leak location, I will sometimes cover the area in foamy glass cleaner, then puff shop air into the engine's breather tube very carefully, to pressurize the crankcase very slightly. You will see the glass cleaner bubble right where the leak is.
Old Dec 26, 2009 | 06:51 PM
R.T.D.H.S.P.'s Avatar
Timing cover gasket...get the good one from Cummins
Old Dec 26, 2009 | 09:48 PM
SWC's Avatar
SWC
I had a leak on the front the kind tourquefan described. His method of finding the leak is excellent advice. He obviously has lots of experience at this.
Stan
Old Dec 26, 2009 | 10:53 PM
SSchofield's Avatar
I had an oil leak coming from the timing cover here about 3 weeks ago. My local Cummins shop suggested that I start simple. So, I did: I tightened up the timing cover bolts... and whattaya know... some of the bolts were loose. Ever since then, my oil leak below the water pump @ the timing cover is non existent. My oil level has not dropped, nor have I had any puddles, leaks, or any HINT of oil leaving my engine to migrate anywhere. Life could NOT be bettah.
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
