Oil Leak
Old Apr 19, 2007 | 09:00 AM
shakin_dodge's Avatar
Oil Leak
Alright guys I have an oil leak on my 1999 Cummins it is leaking pretty bad.. It looks to be coming from the front of the block it is blowing back and covering everything, my axle, my trans, steering arms and I cant really see where exactlly the problem is? Have anyone had similar or smae problem? Thanks
-Metcalf-
Old Apr 19, 2007 | 09:47 AM
b4wheeler's Avatar
It is either the breather tube, or the vacuum pump.
Both of mine are leaking and coating the entire underside of the truck in oil.
It is my little built-in rust prevention system....
Old Apr 19, 2007 | 10:43 AM
farmer dave's Avatar
First of all WELCOME to the site. You will be able to find a lot of answers and good information on the site and the people are great.
Look between the vacuum pump and power steering pump. If it looks wet and shiny then I would lean towards the vacuum pump being the problem. If it is the vacuum pump then look at www.fixinrams.com for a kit to fix it.
Old Apr 19, 2007 | 10:50 AM
newconcorddodge's Avatar
I tried to wipe some of the oil off of all of that last night because i got yelled at about getting oil all over the concrete. I have had my truck a year and havent' had any problems with dripping but last month it got really bad so i have been keeping my eye out since i cannnot believe all of that was from the breather. I keep checking my oil level but it is still in the middle of safe. Hopefully its not something major.
Old Apr 19, 2007 | 11:19 AM
If it started getting really bad with no warning I would guess it to be the vacuum pump seal. But I would check to make sure first before ordering the kit.
Old Apr 19, 2007 | 07:46 PM
thanks guys I am glad for the help it does look really wet right behind the power steering pump and also on the blow by tube... but I stuck my pinky in the blow by and it was powder dry so that makes sense for it to be the vacuum. Also which kit would I need the front one 189.00 or the seal kit 59.00
Old Apr 19, 2007 | 09:02 PM
Break Away's Avatar
You can also get a repair kit from Cummins...part # 4089742...less than $10.00...instructions included.
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
