oil coming out of blow by tube
Its a 99 Dodge 2500 24v, with 95,000 miles, i have seen oil sprayed before on left driver side front axle, after I've towed a trailer. The problem is I havent been towing a trailer, just driving it back and fourth to work ( 1hr each way) and have been noticing alot of oil seeming to be coming from the tube. Just wonder what this might be a sign of? Havent overfilled the oil, so it couldnt be that!
Thanks!
Thanks!
Not sure the screen will block a liquid but I am thinking you have a vacuum pump seal that is leaking.
Same area and I also thought mine was leaking out the puke bottle. After relocating it with a length of hose I still have a minor leak from the vac pump.
Its on the FIWTP list!
(Fix It When Time Permits)
Diesel-Dan
11-06-2016 12:31 AM
